Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 05-02-2015, 02:58 PM
Default 2182 Partial throttle surge.
2182 Partial throttle surge issue. Well after 3 years I finally found out what has been causing the surge in my 2182. It would idle fine and run wide open but at just a bit over idle it had a horrible surge. Funny thing is only one of my 2182's was doing this. I've even replaced the carb. Today I was working on the last one I picked up because it had a low power problem that turned out to be a governor that was way out of whack, fixed that and it made it run like a new one. So I figured I should check the other one, it needed a little adjustment. Anyway while I had it running with the side cover off I noticed that the spring that connects the throttle linage to the governor was vibrating and the engine was surging, put my finger against it to stop the vibration and the surging stoped. You have got to be kidding me! Unhooked the spring, put a half twist in it and end of problem.
Procedure for adjusting the governor is super simple. With the engine off set the throttle at wide open so that the carb is fully open. Loosen the nut on the governor control and with a flat blade screw driver turn the governor shaft fully clockwise looking at it from the top. Hold the governor shaft and tighten the nut back up. You'll need a 12mm wrench for the nut.
Old 05-02-2015, 04:56 PM
raytasch raytasch is offline
I must file that away in the unusual problems/fixes section of the brain. Vibrations can give unusual problems. Just ask any rotary wind aircraft mechanic.
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 05-02-2015, 06:22 PM
Andy2182's Avatar
Andy2182 Andy2182 is offline
Hey Sam, put this link in the page of links that you send to everyone. I haven't had a gasser out yet this year to try this but it makes sense. Been playing with the diesels. Thanks for continually tinkering with these Sam!
Old 03-12-2021, 02:17 AM
Bryan S Bryan S is offline
Before anybody says that you know this thread is almost 6 years old?
Why Yes, Yes I do.
I found this thread last fall and finally got around to trying the finger on the spring thing. YEP! sure enough the surge stopped.
I have had this same issue with my 2182, for way longer
than 3 years, very irritating/frustrating, as Sam mentioned.
But I wanted to first and foremost, thank Sam for posting this.
And second, bring this threadout from the weeds, in the hope that it might help somebody else out.
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 03-12-2021, 05:47 PM
Glad to help.
Old 03-14-2021, 03:30 AM
Sam, what's really odd is I didn't do anything,
other than I put my index finger on the spring,
which was vibrating violently, and when I did,
the spring turned a little bit and the surging stopped.
Spring still vibrating so...
Fired it up today, and drove it down to the neighbor's
house and no surging while sitting there talking to him for a few.
Just a real head
Old 03-01-2022, 01:47 PM
malchren's Avatar
malchren malchren is offline
mine does the same thing. going to have to try this after work and see if its the same issue.
I think we all got yellow fever at this point.
