Old 04-07-2011, 11:08 PM
ramman16248 ramman16248 is offline
Default 1 inch bearings for Douglas wheels.
Does anyone here know if they make a bearing for the Douglas wheel (spindle mount) that will fit my 1811 Cub It is a 1 inch spindle. I bought a new set from Miller Tire co. and got 3/4 inch bearings. If they do make them, will they fit my new hubs? Thanks, jason
Old 04-08-2011, 06:23 AM
Since you are trying to locate Non Cub Cadet Parts for your tractor, I would suggest that you start with
(A) The wheel manufacturer - Douglas Wheel
(B) The supplier that sold you the wheels
(C) Any major Bearing Supply House (ie: Motion Industries)
Old 04-09-2011, 01:12 AM
westofb's Avatar
westofb westofb is offline
I would think most auto parts stores would be able to look up bearings by the outside and inside diameters, if you can get them to do it. Do the cub wheels for 1" spindles differ in outside diameter of the bearing as compared to older cubs with the 3/4" spindles?
Jeff
Brookfield, MO
________________
Old 04-09-2011, 10:06 PM
CubQuest CubQuest is offline
Yes. the bearings for 3/4" spindles have a 1-3/8" OD and the 1" bearings have an OD of 2".
Old 04-09-2011, 10:33 PM
Jason
All the aluminum front wheels I've been able to find online have either 5/8" or 3/4" bearings. If you can't find wheels to fit your 1" spindles you could swap in a front axle or spindles from a wide frame or early quiet line with 3/4" spindle.
Old 04-09-2011, 11:30 PM
I have a set coming in a couple of days froma buddy of mine. It was easier to switch the spindle than try to find a tricky sized bearing. (Actually, the spindles cost less than most bearings that were close in size.) LOL!!!
