Old 12-03-2010, 10:59 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Some 105 progress
Well I posted up my find a week or so ago. Its a 105 that I bought for $50. I just recently put a new key switch, fixed the wire harness, cleaned the fuel sediment bowl, replaced the metal fuel line with fittings and rubber gas line, And rebuilt my first carb !! Its the Walbro I took off my 127, But hey, It was my first one and it was a learning experience, and it works !! Yay me !!
[IMG]hhttp://jlefantephoto.smugmug.com/Machines/Cub-105/DSC5940/1113706657_3v7Cu-M.jpgttp://[/IMG]
short video of it running on first startup
http://jlefantephoto.smugmug.com/Mac...13706492_EhAB6
Old 12-03-2010, 11:02 PM
Great pics and vid, Jay! The 105 sounds great!
Old 12-03-2010, 11:05 PM
juniors1282's Avatar
Nothin wrong with that, sounds great, congrats. Keep up the good work!
1966 IH cub cadet 102x2
Old 12-03-2010, 11:21 PM
Default Thanks
Thanks guys, Anyone have any ideas how to get that darn pipe out of the block to throw that exhaust out? I used pb blaster and saked it for days and used a big pipe wrench, and nothing......it started to bend the pipe, its kinda weak.
Old 12-04-2010, 12:20 AM
Sminkey
Guest
Posts: n/a
Sounds good, thanks for the vid. I had the same issue on my k161, I soaked it with pb and started pipe wrenching it and the pipe started crushing, at that point I was all in so I heated it up as much as I could with propane torch and wrenched again with a pipe on wrench for extra leverage and got lucky, she broke free! That's a tough one, good luck!
Old 12-04-2010, 02:16 PM
If it is that week, I would almost try to cut it just long of the block and use a cold chisel and punch to try and push and cut it out. If it messes the threads you can drill the bosses on either side of the outlet and order or have an exhaust shop make a flange adapter for a muffler. Some of the puller websites have pipes already made up with the flange for use with the two bolts.
Old 12-04-2010, 02:50 PM
gcbailey's Avatar
gcbailey gcbailey is offline
nice progress... that engine does sound good!!
Gary
Old 12-04-2010, 04:39 PM
Default ha
Thanks Gary. So my little guy goes in the garage and says dad, you know what this thing needs, "A BIG bottle of Rust-eze !!! """"
Old 12-04-2010, 05:02 PM
gcbailey's Avatar
hahaha!!! that's funny. Looks like it needs some of that bumper ointment...
Gary
Old 12-05-2010, 07:01 AM
Default For Gary
Gary here are the new siblings.....The funny thing is they are both from 1969.....
