Old 10-25-2010, 12:26 PM
108cubber 108cubber is offline
Question 108 hood latch
Hello all! Got a challenge with my 108 hood latch mechanism. The latches are there, but the metal piece is missing from the hood. If some one could give the dimensions of its location, I can put in a new piece. I would like for the dimensions to be from the lower rear corner of the hood if possible.
Also the inside width of the hood would help. Thanks!
Old 10-26-2010, 05:18 PM
Guess I'll just wing it.
Old 10-27-2010, 01:14 PM
108 cubber,
The bracket is 13 5/8" long at the outside of the bends and 1/8" thick.
The bent tabs are 1" from inside of bend.
The bracket is 1" wide.
It is 5/8" from the back edge off the hood, and 2 1/8" from the bottom edge of the hood.
Hope this helps...
Old 10-27-2010, 05:16 PM
Thank you so much for this info. I could have put it where it "felt good", but wanted to stay close to original specs. Again, I say thanks.
