Old 05-11-2009, 10:36 PM
jcrews's Avatar
jcrews jcrews is offline
Default Hydro Shifter Repair
Hello
Well I got my 1450 running today and I managed to break the hydrostatic shifter on the dash . Well I thought after looking at the break I thought I could fix it. I drilled through the metal behind the break and put two pieces 1/8 inch aluminum on each side and threaded the holes with a tap & die set and ran screws through it and it seems stronger than before ( I'll cut the screws off tomorrow.)
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 05-11-2009, 11:29 PM
67hydro's Avatar
67hydro 67hydro is offline
good fix,and alot easier than finding a new one!!!
Jason
Old 05-12-2009, 09:07 AM
Exclamation
I'd highly recommend putting locktite on those screws... You don't want that falling apart when you are driving it
Old 05-12-2009, 11:51 AM
klejeune's Avatar
klejeune klejeune is offline
Matt, there's always the brake pedal!
Don't you hate it when you've got a couple Cubs out working and you jump from a gear drive to a hydro and hit the brake pedal to stop instead of using the hydro lever?
I like pie
