Old 09-10-2023, 12:02 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
Default K161 carb kit
I just put my K161 carb back together and had issues with the rebuild kit I found online. The bowl gaskets and float pin are the only parts that are actually the right size.
The inlet valve was the wrong thread pitch and the bowl nut washer was oversized so I used the washer that was meant to be for the inlet valve, but it still isn't a good fit and doesn't completely seal.
All the k161 kits I see look like the same one I ordered, some Chinese knockoff. Are all the parts for the rebuild kits interchangeable? I bought a genuine Kohler rebuild kit for my k241, are all those parts interchangeable on the different Carter carb sizes?
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 09-10-2023, 05:41 PM
Is the carb a carter?
Up to 530 and counting...
Old 09-10-2023, 06:21 PM
Graflex45's Avatar
Yes a Carter model N
Old 09-10-2023, 06:41 PM
Didja get the oem carb kit? 25 757 01-S
Old 09-11-2023, 07:54 AM
Graflex45's Avatar
That's the kit I bought to rebuild the k241 carb, that will work on the small 7hp engines carb too?
Old 09-11-2023, 08:56 AM
yes........
