Old 05-16-2023, 12:45 AM
hossjesse hossjesse is offline
Default 782 w/KT17
Got a 782 cub with kt17 been sitting for a couple of years. I was not getting any spark so I put a new coil on it, still no spark. I got power on both of the small bolts on the coil. Thinking about putting new points and condenser in it but don't know how to make sure the the points are in right if anyone can help with that also and any ideas why im not getting any spark. I don't see any safety switches on the seat , I don't know if it had any before or not. thanks
Old 05-16-2023, 07:00 AM
First, welcome to OCC..........
Most likely, the issue is with the "points". You have two options. (A) Repair, or (B) Replace. The points can easily be cleaned by using some sandpaper (ie: 180 grit or more) or using a "point file". Clean up the contacts and you should be good to go. The condenser hardly ever goes bad (same for the ignition coil).
Neither of these parts are big money. You can purchase both, then you have comfort in knowing all the ignition parts are new.
Old 05-16-2023, 07:25 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I just replaced these on a friend's 782. ONLY use OEM Kohler points and condenser. It's a much better bet your timing will be spot on when you gap the points to the proper specs. The condenser is kinda pricey, since it is designed for the KT17. The points are the same as the K series singles, so they are cheap.
Condenser: KH-52 147 01-S OR KH-52 755 13-S
Points: KH-47 150 03-S
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-18-2023, 03:25 PM
Farmall450's Avatar
Nice info.
Old 05-21-2023, 07:45 AM
gears gears is offline
Definitely the points. Not too big a deal. There are plenty of how to vids on the tube.
Tags
782, no spark
