Old 06-02-2022, 09:53 PM
Farmall450's Avatar
Default Saving a 1982 Yellow & White CCC 782
I acquired this Y/W 784 about a month ago when picking up a 1641. Both were headed to scrap, so they threw in this tractor. Sitting 10-20 years (owner got it in the same condition I did), it has the original KT17 Series II.
I was curious why it still has the IH S/N/Model # system, despite being CCC produced in 1982 (I surmised from the 142 in the model).
782 142 U
700455
My immediate plans are to rebuild the carb (once a kit shows up) and see how she runs. Intake manifold and carb were off when I got it. Fuel pump runs good, and I replaced the lines/filter. Engine being somewhat apart I had assumed it threw a rod like most KT17s like to (I had that experience with a Series II in my 1711, too), but it has good compression and doesn't seem to have any extra holes.
I did have to get a new front tire, and found a matching Turf Saver to compliment the other side. Short term plans are mounting some R1 Goodyears I picked up and adding a sleeve hitch that was destined for the 1811, but seems like a better fit on the cast rear (saves $80 for the Xtreme tabbed ear U hitch).
Jeff should have a Brinly adapter shipping out for me Monday, so outside of fabricating a lift rod to match the one on the 1711 I should be good to go on both of those aspects.
An aside, Rustoleum transport yellow seems to match the Iron Guard I used on the 1811 wheel weights last fall (and goes on a lot better/thicker). If it were a bigger project I'd look harder for Rustoleum Marigold.
File Type: jpg 782 R1 Goodyear Rear Tires Canvas Whtie.jpg (30.0 KB, 186 views)
Old 06-02-2022, 10:01 PM
Farmall450's Avatar
Some pictures of when I first got it (on the trailer) and how it looked tonight.
File Type: jpg 782 R1 Goodyear Rear Tires Canvas White .jpg (25.5 KB, 184 views)
Old 06-03-2022, 07:03 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
That is a super early CCC tractor-probably has the Brownsville Tenn address on the tag, instead of Cleveland, OH.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-03-2022, 07:46 AM
Farmall450's Avatar
Yes, exactly! Thought that was neat. Cast rear too.
Almost seems too early to have the Series II?
Old 06-03-2022, 08:17 AM
1711Cub's Avatar
Lightbulb
The KT17 Series I were installed in Chassis Serial Numbers below 726124.
The KT17 Series II were installed in Chassis Serial Numbers above 726125.
Obviously, almost all the Series I have been replaced due to failures. They are a rare sight today.
Old 06-03-2022, 09:33 AM
Farmall450's Avatar
Thanks -- it would seem this has been replaced. I saw it has the holes in the tin and blockoff on the block for the remote filters...I wonder if my M18 spare ones would bolt right up.
I sold the conversion kit I had back when my other Series II launched a rod. Certainly this one shipped with a Series I, then, but must have been replaced before Magnums were a popular replacement.
Old 06-03-2022, 11:18 AM
1711Cub's Avatar
Wink
The M18 Oil filter bosses will fit the KT17 series II's so equipped with the provisions. Unfortunately, not all Series II's had oil filter provisions!
Old 06-03-2022, 02:06 PM
Farmall450's Avatar
I saw this one had the block off plate and the holes in the shroud for it. I'm not sure what else would be needed besides maybe adding a hole in the firewall (will compare to 1811 mounting).
Probably a value-added improvement.
Old 06-03-2022, 04:57 PM
1711Cub's Avatar
Lightbulb
My 682 has the M18 with the remote oil filter added to the firewall. I drilled a couple of holes to snugly fit it under the fuel tank. I trimmed the firewall to hood/side panel seal to accommodate the flexible oil lines.
Old 06-03-2022, 07:08 PM
Farmall450's Avatar
I'll give it a shot once it proves to be worthy.
Treated the 782 & 984 to new gas caps. Stens 125-280 shows Made in USA, amazingly.
