Old 02-19-2022, 08:14 AM
EternalArianne EternalArianne is offline
Default Help identifying year
The information on the Cub Cadet website appears to only be for the newer stuff. My serial number is only 6 digits long. I know the cubs before 1997 had different serial numbering schemes. Can anyone help me identify what year my 2155 was made?
Model: 13A-244G100
Serial: 362116
Old 02-19-2022, 08:18 AM
Farmall450's Avatar
Model: 13A-244G100
Serial: 362116
1996-1999. I loaned out my 50 years of CC book, but it might not narrow all the way down. Is there a date under the seat on the label w/ the S/N?
Older ones up to cyclops at least always had a date code next to the S/N tag on the frame, where the first letter is also the year of that decade. Ie "E" is 1995, coincidentally they'd end the first 3 of the model code in 5 too.
Old 02-19-2022, 08:20 AM
The model/serial data looks to be incomplete. How about snapping a picture of the tag and posting it.
Old 02-19-2022, 08:26 AM
Here is the label
Old 02-19-2022, 08:38 AM
Another oddity is this tractor has the 42in deck from serial 359000 and below according to the parts diagram, but the serial appears to be higher than that. So unless the deck was swapped out with an earlier one, it's even more confusing...
Old 02-19-2022, 10:11 AM
There is a small tag to right of the main tag. Can you read the characters and post them ?
Old 02-19-2022, 10:25 AM
That's a sticker and it is totally worn away and unreadable unfortunately. You think that was the rest of the model/serial number?
Old 02-19-2022, 10:45 AM
dale c. dale c. is offline
I was thinking that the 4th digit of the serial # is the year , so that would make it a 2001 . but tractor data shows they were built from 96-99 ????????????
Old 02-19-2022, 11:05 AM
Farmall450's Avatar
That is the date code
Old 02-19-2022, 11:15 AM
Whelp, I guess I'll never know. I'd like to think it's one of the earlier ones due to the deck, but the first digits of the serial suggest otherwise...
