Is there a location to purchase just the electrical connections to the gauges, light switch, and ignition?
Everything works I see a hot spot on one connection Considering making my own new wiring harness but need to find these connections for my 1250. Any part numbers listed as I don’t see just the connections as only an option |
There are two ways to go.
(A) There is the inexpensive practical way to and get universally available terminals. or (B) Emulate OEM. It may a little difficult to find and cost more. The terminals can be found but the Molex Housings may be more difficult OEM used 16 GA wire.
Auto parts store should have those.
If the plastic connector housings are not burnt or melted you should be able to reuse them once the wire terminals are removed. https://www.delcity.net/store/Packar...nectors/p_9108 I get all my wire supplies here. You can order as many or as few as you need. You should use the correct crimping tool for best results though and they are not cheap. Good luck! |
Thanks for the info.
I was just wondering if the CCS or The other vendor mentioned were worth it or build my own. Just want to know what’s worth the time being everything I’m doing to by 1250 is being renewed and repainted. Didn’t want 40 year old wiring in this updated tractor. |
They aren’t Molex connectors. They are Packard 56.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Porch Electric is No Longer in Business.
Their website is still up. I sent them an email to be sure.
Porch still has ads up on a certain auction site.
