Hello...
1450 hydro relief valve (older style..not the ' push button' style) leaking from the tiny weep hole in top....i read where you can not just block it off because you can not 'push the tractor'....thoughts on drill n tap and put in a small pipe plug...if I do need to push the tractor I can remove the pipe plug? If possivbe, how far can i drill in ? Just about 1/4 to 3/8 deep? |
The one without the button is an automatic one and actually the newer style. It is leaking out the hole because it is worn out. Contact this company. They can rebuild yours for a fraction of the cost of new.
Machtech Direct 605 Furnace Rd. Conneaut Ohio 44030 Phone: 440-499-5813 Email: mark.machtech@gmail.com
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
![]() Quote:
Just think of it as if something plugged yer relief hole, you wouldn't move. Then bad things happen ![]() |
It leaks now but it is repairable, as mentioned above.
If you drill and plug, and it doesn't work, you will have trashed a repairable relief valve, and now you will be buying a condition unknown used one, or a brand new one at greater cost. Make sense? |
The hole in the top of the relief valve is a "vent hole". Do NOT plug this hole.
Thanks for the input...first time in my research I heard they could not be plugged. Makes sense !
No that it matters and everybody knows what's being talked about but; they are actually "release" valves and not "relief" valves. Hence why you can't push your tractor when plugged or for the older push bottoms, when they're in the up position.
It's only a terminology issue when someone says "shim your relief valve". ![]() |
