Hey guys,
I've got an 1882 with a 60" Haban deck I'm going to be selling soon, and I have no idea what it should be worth. Somebody gave it to me, I did enough work to make it run and mow grass but it needs a bunch of work and I don't have the time. And I have way too many trees to mow around; that big Haban is great in flat spaces but it's cumbersome around the trees. I plan on peddling it and getting a ZTR The good: New deck wheels One new head gasket New stator coil Fresh epoxy on the flywheel magnets (that was fun) Deck spindles are tight New rear tires Hydro seems perfect 44" snowblower that works (with some spare parts) The bad: Steering gear leaks, drips once it's warm Steering cylinder seeps and has a mind of its own Plastic hoods are beat, cracked and faded, missing grill Rear fender paint is peeling Front tires are bald Wheels bearings, tie rod ends are loose Wiring is kind of a mess Kohler Magnum is tired, could use a refresh Thanks for the thoughts, I'm not out to screw anybody over but I want to get what it's worth. Disclaimer: I still have an 1811 that I'm never getting rid of, so don't think I'm getting out of Cub Cadets
First,
. As always stated, pictures are helpful when assessing values. From what you stated, I would place the value somewhere between $800-$1200. Area and mechanical ability of buyer may also play a factor in the selling price (not necessarily value, though). Your Haban deck is worth around $400 with the undercarriage. That's not far from what I paid for one just about a year ago. Of course, piecing it out will always be more profitable than selling it as an entire package. A lot of your bad is not THAT bad and could easily be fixed or overlooked, like the paint peeling can be overlooked as most of us have cubs with paint peeling or chipping. The front tires, wheel bearings, and tie rod ends are easily replaced for a benny, give or take. The wiring could possibly be cleaned up easily with some new wiring (and/or fittings). Does the engine just need a tune up or does it really need an overhaul? That could be the most significant part of money spent on repairs, so maybe a tune up might be all that it needs. If your cub is in "good" running shape, then in my area it would bring around $1200-$1800. Glad you are keeping a cub back for your use. Cub Cadet 123
