Old 01-19-2021, 11:35 AM
SDBOB SDBOB is offline
Default Thinking of buying plans for front loader
I have 2 wide frame parts tractors, 149 and a 129. I'm thinking of buying plans from PF Engineering. I do not need loader all the time just occasionally to move top soil or stone. I've welded many 'tools' over the years. I have steel. I have small hydraulic cylinders and valves I was given. So I'm thinking for a project. Should I reinforce frame? Front end? Any suggestions would be appreciated.
Old 01-23-2021, 10:15 AM
If it helps, I know where there is a frame for sale for under $200, if the fella still has it. It just needs a bucket and the hydraulics with pump added to it, then you are in business. It would have to be shipped, unless you are interested in making a field trip. Let me know if that will help you out.
Old 01-23-2021, 02:59 PM
Yes I'd be interested. I sent you aessage
Old 01-23-2021, 04:20 PM
Check out Cadplans. John is one of our members.
https://cadplans.com/collections/loaders
Old 01-23-2021, 08:02 PM
I hope you were able to secure the frame. I have a danco loader on my 106 for over twenty years now. no axle changes, no larger hubs, no modification to bigger bearings, but I did add the steering bearing to ease the steering effort and it helped alot. I use it every summer. I put new bearings in the front wheels about 2000 when I changed the tires(replaced dry rotted original ribs). at the time the only 6 ply tires I could find was an ag tread tire so it has ag's front and rear. I have a 2a tiller mounted for counter weight.
Old 01-23-2021, 09:19 PM
Thank you guys.
Old 01-24-2021, 09:30 PM
Private Message Sent (PMS). I have done business with the guy multiple times. He knows his cubs inside and out and does work for people around the country on their cubs via shipping. Hopefully, that will get you a start for one.
