Old 08-10-2010, 11:40 PM
tubbyfirefighter's Avatar
tubbyfirefighter tubbyfirefighter is offline
Default Spirol Pin
what size spirol pins do i need for the drive shaft of a 1450, price and where can i get them? Thanks
I'm not fat, I'm just fluffy
Old 08-11-2010, 06:08 AM
I thought this would be an easy question. Much to my surprise, I looked up the Parts Manual for the 1450 and could not find the drive shaft spirol pins on line. I went to my paper version and again, saw no listing for the spirol pins.
IIRC, seems that they are 1/4" in Diameter and 1-1/2" long.
They can be had at.... McMaster-Carr
Old 08-11-2010, 07:33 AM
The local Ace Hardware carrys the 1/4" spiral pins. I picked up a pack there when I rebuilt my drive shaft.
Old 08-11-2010, 11:17 AM
Wayne Wayne is offline
I know I got 1/4 inch pins at my local Ace too.
Old 08-12-2010, 09:55 PM
from mcmaster do i need to get standard or heavy duty? Would stainless be better?
Old 08-12-2010, 10:00 PM
Heavy duty. I don't think I'd bother with the SS ones; they're expensive and not any stronger.
Old 08-13-2010, 09:24 AM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Roland - all but one of the 'Spirol' pins for the 1450 hydro-transmission assy got lumped together under Part 7 'Self Aligning Ball Bushing', and specifies three 1/4" x 1 3/8" Heavy Coiled Spring Pins.
I checked my local Ace, True-Value, TSC, Lowes, H-D, and other hardware stores and all I can find are Roll (aka Tension) springs. DX3 - I'm wondering if you actually found coiled spring pins (aka Spirol pins).
On the left is a Coiled Spring pin, on the right is a Roll (Tension) pin. Spirol is a brand name for their coiled spring pin, much like Xerox has become synonomous for photocopy.
File Type: jpg Spirol, coiled pin vs Roll, tension pin.jpg (16.4 KB, 129 views)
Old 08-13-2010, 11:53 AM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
i work at a cheese manufacture facility and we have miles of stainless pipes and thousands of stainless bolts, been there for 30+ years and i can tell you that you do not use it for it's strength properties. you use stainless because it is easy to clean and maintain a sanitary environment.
have seen many a bolt striped out over the years that if it was not stainless would not have, stainless is softer but shiny and easy to maintain, rust wise
Old 08-13-2010, 01:26 PM
Actually, the McMaster-Carr spirol pins in SS and regular steel have the same double shear strength (SS ones are 420 if you were curious) but they cost 5x as much. I do agree on the strength though; most people have this misconception that the SS hardware store bolts are stronger than a Grade 5, when in fact many are weaker than Grade 2 bolts.
Old 08-13-2010, 01:34 PM
As soon as I get the camera back I'll show you a picture of the Coiled spring pin I purchased at Ace . Something to remember is, not all stores carry the same items in all areas of the country.
