Old 08-10-2010, 04:11 PM
GrantC GrantC is offline
Default Steering rebuild
Planning on pulling the steering column on my new 123 and fixing the slop. I've seen the article in the archives about rebuilding the steering box, and the recommendation of a thrust bearing.
I also read somewhere about adding a bearing at the top of the column to replace the plastic bushing. I've searched and can't find the info. Was it my imagination, or can someone give me the bearing number for that application?
-=[ Grant ]=-
Old 08-10-2010, 04:21 PM
ljones's Avatar
ljones ljones is offline
The thrust berring is almost like power sterring you can get one here http://www.kirkengines.com/
You can get the berring for the top of the colem here http://ccspecialties.org/steering_seats.html
Combine these two and you will have some GOOD sterring
Old 08-10-2010, 04:52 PM
Merk Merk is offline
Page 5 of this topic
Has a write up on how I rebuild the steering in my 70.
Old 08-10-2010, 10:13 PM
That link was very helpful, Merk. One question - does McMaster carry the bearing for the top of the steering column?
-=[ Grant ]=-
Old 08-10-2010, 10:23 PM
I don't think they do. You can use a CC front wheel bearing if you wrap a piece of shim stock around the OD.
One comment about that thrust bearing in Merk's thread...it's totally open and will get dirty more easily, and that'll make it turn hard, and then you're back where you were again. The (shielded) thrust bearing most people use is a 'Nice 605' and any good bearing supply place can get it. The last time I bought a few, they were less than $2 each.
Old 08-10-2010, 10:25 PM
Lmercer Lmercer is offline
I bought a wheel bearing from my Cub Dealer. 3/4" ID X 1-3/8" OD
Old 08-10-2010, 10:56 PM
cub149's Avatar
cub149 cub149 is offline
I don't think they do. The (shielded) thrust bearing most people use is a 'Nice 605' and any good bearing supply place can get it. The last time I bought a few, they were less than $2 each.
I have seen this talked about all around but I don't know about bearings, so... Is the 605 a size reference or a model reference. What size would one buy? Also, what size washers would one get to go along with it? Or is it as simple as getting the one that has the ID of the OD of the bolt.
Chip T.
Drexel NC
Old 08-10-2010, 11:04 PM
That is the manufacturer and model number of the bearing. It is essentially sealed from the outside and both races are built in, but you'll still need one washer. The one that was originally under the two jam nuts works fine.
Old 08-11-2010, 10:33 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
The bearing for the top of the steering column is a Hillman brand Radial Bearing 3/4" x 1-3/8". Hillman number 838627. I stumbled upon a supply of them at Tractor Supply Co. in the aisle with all the pull-out trays of nuts & bolts. The TSC number is 3772591, $3.29 each, and they are individually bagged.
If you're wondering, the bearing is stamped "Freeway Cleveland Ohio ... ASF"
Old 08-12-2010, 01:11 PM
I notice in the rebuild pics that there is a foam seal on the side of the gearbox, which I suspect will need to be replaced.
Then I looked up the part and found out how much it costs!
Is there an alternative?
-=[ Grant ]=-
