Old 06-26-2020, 11:25 AM
martyrant martyrant is offline
Default 1250 no spark
Alright, so I tried to do my due diligence here but I still have a question after doing research and troubleshooting.
I read this thread to help troubleshoot since it seemed to be a similar problem and is the same model:
https://www.onlycubcadets.net/forum/...ad.php?t=44422
I followed J-Mech's suggestion of using a test light to ground and then attaching it to the - side of the coil while cranking the engine. This produced no flashing, and I double checked it with a multimeter as well. So following his logic, it could be the points, the wire to the points from the coil, a bad coil, or the unlikely problem of a condenser.
I double checked the wire from the points to the coil, removed it, inspected it and it looks good and continuity with a multi-meter passes fine. I checked continuity with it installed as well and it was good.
I replaced the condenser since I was able to find one locally for $8 and said what the heck. No changes.
I tested the coil using the method found here under the tech library:
https://www.onlycubcadets.net/forum/showthread.php?t=27
And it tested good. I was convinced it was the coil regardless because I saw a weird reading once or twice, so I brought it over my neighbor's (who has a 1976 John Deere 316) and swapped my coil onto his tractor and it started and ran as normal.
So that leaves the points -- I have a question, though. With the key ignition on, if I separate the points with a screwdriver slightly shouldn't there be a spark? I am getting zero life at the points. I did file them and checked timing -- it all looks good, but there's no power there whatsoever.
Anyone have an idea of what I'm missing here...? Driving myself nuts and it can't be that complicated I'd think. I checked the manual but it doesn't seem to have troubleshooting for electrical issues that I could see.
Old 06-26-2020, 11:53 AM
green407's Avatar
green407 green407 is offline
This maybe an odd question, but do you have reliable loadable power to the "+" side of the coil? (I didn't see this mentioned anywhere in you post)
As R Bedell has stated make sure your grounds are good too. nothing is more frustrating when chasing a power problem and it's only a bad ground.
Yes you should get a spark when you separate the points with the ignition switch on.
128 X 2, 129, 149, 1250, 1450 x 2
Old 06-26-2020, 12:08 PM
The "points" is the ground side of the Ignition System.
AS A TEST..... with your DVM, do you have zero ohms between the Battery negative terminal and the mounting screw of the points ???
So it's reading .1-.2, so bad ground somewhere? I'm currently bypassing the PTO and Clutch/Brake safety switch to troubleshoot, so does that eliminate them out or is there a way to isolate things?
Yes, I am getting 12v to the + side of the coil when the ignition is turned on.
Old 06-26-2020, 07:26 PM
ironman's Avatar
ironman ironman is offline
Then check the negative post of the coil with the ignition on.
If the points are open, you should see 12 volts,
if the points are closed you will see zero volts.
If the points are open and you see zero volts,
there is someting wong with your points (since you know the coil is good)
Old 06-30-2020, 12:32 PM
crazycubtrio crazycubtrio is offline
With your voltmeter set on ohms, key off, hook one lead to the - side of the coil and the other to one of the points mounting screws. With the points closed the meter should show.1 to .2 on the meter, lift the movable part of the points away and you should see infinity. It sounds like a classic case of crud across the contacts that you can’t see. Get a tiny flat screwdriver and scrape both sides until you see continuity. Put everything back together and enjoy
Old 07-04-2020, 10:34 AM
Sorry, took me a few days to get time to get back to this...just tried running a jumper wire from battery negative terminal to the points, key on, still nothing when I open the points gently with a flathead. Can points themselves go bad? Or am I missing something else here?
Old 07-04-2020, 12:18 PM
AndrewNoyes AndrewNoyes is offline
I suggest starting right at the switch.
Old 07-04-2020, 12:50 PM
I have voltage there to the coil with the key on, so I think that is okay?
Old 07-04-2020, 01:30 PM
ironman's Avatar
Where on the points did you connect the jumper wire to? If you went on the screw terminal, this test tells you nothing.
This problem is a simple matter of battery and ground, and is one of them missing. There is no reason for this to be so difficult.
The simplest thing you have to do is disconnect completely the wire from the negative side of the coil, that is, the wire going to the points.
Put a meter or a light on the lug of the coil where you took the wire off.
Turn the key on and off. If the light or meter shows 12 volts working with the key then your good from the key switch. If not, your coil could be bad or pursue the trouble towards the switch.
If the trouble is not coming from the switch or the coil,.....
Then set your meter to ohms and connect one lead to ground on the engine block and the other lead to the end of the wire that you took off of the coil.
When the points are closed you will see continuity to ground.
Rotate the engine by hand until the points open and you should lose the continuity to ground.
If you do not lose continuity when the points open, the points are shorted.....replace them.
If you do not see any continuity when the points are closedl, the points are not making contact when they close, clean the contacts or better yet replace them.
Old 07-04-2020, 01:43 PM
I put it on the screw that holds the points on the engine plate.
Story of my life.
Sorry, maybe this is the problem -- I just want to clarify...
When the key switch is on, I have 12v to the + positive side of the coil (not the one going to the points).
On the negative side of the coil there is no voltage with just the key switch on. I thought there should not be 12v there until the engine turns over?
Just want to double check as you specifically bolded the negative side.
