Old 07-24-2019, 05:31 AM
mrfred54 mrfred54 is offline
Default K301
Are the balance gears a necessity in these motors. Some have them and some don't. Had anyone not put them back in the block during an overhaul???
Old 07-24-2019, 07:10 AM
The short answer is .... NO.
Old 07-24-2019, 11:44 AM
jzidle jzidle is offline
Do all of the Kohler K301s have them or is there a date after which they were no longer used?
Old 07-24-2019, 12:56 PM
mortten mortten is offline
I think they started with the wide frames around 1971. I have engines out of 122’s and a 125 That don’t have them. I have a 1974 service engine that had them but are now removed.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-24-2019, 04:46 PM
So, my very late replacement motor definitely has them?
Old 07-24-2019, 05:49 PM
It would guess it does if it’s not an AQS. Never saw one with balance gears in it. Drop the oil pan and see if they’re in there.
Doug
QA-36A
42" blade
Old 07-24-2019, 06:25 PM
dodge trucker dodge trucker is offline
I didn't think that it was a year thing "up to/after" with the balance gears. I thought it was a spec number thing, engines from each year that these engines were built, that were built either way, with or without the balance gears. I haven't been inside many kohlers that haven't had balance gears but once I get inside, none of them have their balance gears any more.
Old 07-24-2019, 07:42 PM
I would agree.
Old 07-24-2019, 07:56 PM
I was using a year for reference. A 127 does not show balance gears in the parts lookup. The 129 does. I would guess that serial numbers higher than 30XXXXX have gears but that’s just my guess. The only reference to serial numbers in the Kohler manual is for changes to the bearings and gears through the years. The manual does say this:
“Most K321 And K341 K-Series engines are equipped with a balance gear system. K91, K161, and K181 engines do not have balance gears. Some K241 and K301 engines are equipped well th a balance gear system.”
Doug
QA-36A
42" blade
Old 07-25-2019, 07:10 AM
I believe this one won't have them anymore either. Thanks
