Old 01-27-2019, 12:21 PM
Cambria cub Cambria cub is offline
Default Hydraulics help
Just got done putting a jd 2 way hydraulic spool valve in my 1811 and can't get the handles to move like it's stuck won't go up or down
Old 01-27-2019, 01:05 PM
cooperino's Avatar
Sounds like the hydraulics are dead heading.. Show us a diagram of your hydraulics.
Old 01-27-2019, 01:46 PM
yeeter yeeter is offline
Do you mean the handles are locked and wont move?
Or when the handles are moved, nothing happens?
Old 01-27-2019, 02:19 PM
Handles won't move at all can't get them to come up
Old 01-27-2019, 02:28 PM
Tee off for pair in back to when I took the line in off to check there was fluid coming out
Old 01-27-2019, 03:30 PM
Had that happen to me once on my 1450. The shafts coming out of the top of the valve, apparently got some rain (???) on them. They rusted, and they wouldn't move. I sprayed some PB Blaster on them. Let it set for about 10 minutes. Gently tapped on them. They broke loose and haven't had a problem since.
Old 01-27-2019, 03:42 PM
DieselDoctor's Avatar
If it's hydraulic pressure holding them, they should move freely with the engine off since there will be no pressure present.
If they still don't move with the engine off, disconnect the linkage. Does the linkage move freely? If so, then the problem is in the valve itself, most likely stuck from moisture as Roland has said.
Old 01-27-2019, 04:12 PM
I can turn them around and around but will not come up or down will shoot some PB on them
Old 01-27-2019, 05:33 PM
Smile
Ok got them to go up and it works just got to tighten stuff up Thanks a lot guys
Old 01-28-2019, 11:17 AM
When installing used components (and new for that matter) it's best to check the operation of the moving parts BEFORE you install them.
