Old 11-14-2018, 08:29 PM
DewDrop DewDrop is offline
Default This is what $22 got me today.
I just recently purchased my 127, got it running, found a snowthrower for it, and got it (almost) all set up for winter. I had to make a lift handle bracket for it, which i just shot with some primer. I plan on hopefully repainting the tractor next summer. And please don’t mind my lift ‘cable’ it is temporary because the lift rod that came with the snow thrower was way too short. I am going to attempt to make one tomorrow. I’m sure this has been done, but I wanted to give it a try.
I picked up a mighty lift hood strut part number D95795 from a parts store. It has a lift rating of 201 lbs. All I needed to do was run the stud through my makeshift lift bracket, and one of the holes already in the frame, and fasten a nut to the back side. I did have to compress the strut with a ratchet strap first. Once installed, the snowthrower lifts amazingly smooth and easy. I’m sure you could run it on the inside somewhere, out of sight. We shall see how it holds up this winter. It does come with a 1 year warranty, some of the other models have a limited lifetime warranty.
File Type: jpg C713A758-7833-4DBD-9C95-B11BE70287E9.jpg (22.7 KB, 260 views)
File Type: jpg 886BCA1C-A807-4567-90D1-19025732273F.jpg (20.6 KB, 257 views)
File Type: jpg 03B861BD-0935-4BF5-8878-70E3FD35FDFE.jpg (17.8 KB, 257 views)
Old 11-14-2018, 08:33 PM
Tom Dowling Tom Dowling is offline
Good idea!
Old 11-14-2018, 08:35 PM
Uh, what size snow thrower are you using and what is it's weight?
Simon Bletzer
Old 11-14-2018, 08:40 PM
Simon Bletzer
QA-42A - 42 inch, I’m not sure of the weight. It was plenty heavy with no assist.
Old 11-14-2018, 08:42 PM
I forget the specs on it, but I believe the 42's are around 225 lbs. and the 36's are around 185 lbs.
Check your warranty on that strut. If it is rated for 201 lbs. you might be disappointed when you are sitting at the end of your driveway in a snow storm with a snow thrower that won't lift off the ground.
EDIT: I suppose you could always disconnect the strut and Armstrong lift it up to get it back into the garage.
Simon Bletzer
Old 11-14-2018, 09:35 PM
Simon Bletzer
It's sole purpose in life is to assist. It’s not intended to lift the unit by itself. Even when it does one day fail, you wouldn’t have to disconnect it, it will just be back to where it was with no assist. It’s like a spring assist, if the spring fails, you can still use it without needing to disconnect anything, you just need a little more muscle.
Old 11-15-2018, 12:38 AM
Farmall450's Avatar
^ What he said!
Old 11-15-2018, 05:32 AM
twoton twoton is offline
Looks good there DewDrop.
Old 11-15-2018, 06:40 AM
cooperino's Avatar
I like it! Lil ingenuity
Old 11-15-2018, 07:23 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Good idea! I guess one strut isn't quite strong enough, you could add another one!?!
Plow blade
#2 Cart
QA36 snowthower
