1977 cub 1650. Wanting to change hydro fluid and filter. I read somewhere on this site it says 14 pts. Is this number correct? Thanks
You can read through the operators manual and it'll tell you all the specs and capacities. It's located in the tech section on this site. Link provided for ease of access.
http://www.onlycubcadets.net/forum/s...ead.php?t=4670 |
Correct, 7 quarts.
Ok thank you
You might already know this, but just in case, when you change the fluid, you will need to remove the cover. The fluid will quickly pour out, so wear eye/face protection and have a container large enough to contain all of the fluid. Some of the fluid will remain in the axle housings. Once you remove the rear cover plate, then you are likely to need to replace the gasket for it, so remember your gasket when you are purchasing your materials.
Happy Cubbin' Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
