Greg Rozar AKA- CubDieselFan
Old 03-11-2018, 09:24 AM
Steve62 Steve62 is offline
Default Kohler CH22S Smokes on Start up
My 3206's engine only smokes on start up, the longer it sits, the more it smokes when started. After that, no white smoke at all.
Does this most likely mean the valve stem seals need to be replaced ?
Old 03-11-2018, 06:02 PM
CubDieselFan's Avatar
You said white smoke, right? Oil some is more a blueish color.
Old 03-11-2018, 08:34 PM
You know, I started to write "blue/white smoke" but then I thought, any whitish smoke is to be considered caused by oil. At least as far as I know. So yes, it's sorta blueish/white smoke.
After posting here, I then saw the Kohler engines sub forum. Guess I should have placed it there.
Old 03-11-2018, 09:08 PM
Bad head gasket, valve seals or even worn out rings can cause oil smoke. You will just have to take the engine apart and see what you find. Only way to diagnose that issue.
Old 03-12-2018, 11:10 AM
mickb72 mickb72 is offline
See if it fouls one spark plug more than the other. Mike
Old 03-12-2018, 07:24 PM
Right, I had just put in new plugs and have only run it a couple hours so hopefully they will show something.
Thanks Mike !
Thread Tools
Display Modes
