Old 01-29-2018, 01:00 PM
jakeotter jakeotter is offline
Default Cub Cadet 72 fluid in rear tires
Hi do you all think a cub 72 would run ok with windshield washer fluid in the rear tires? I live in a hilly area and this would help with stability and traction. I wasn’t sure if the 7hp was up to that added weight.
Thanks!
Old 01-29-2018, 01:22 PM
No problem!!
I run it in 3 of my cubs and use tubes in them.
Old 01-29-2018, 08:48 PM
Workingstiff Workingstiff is offline
If I were going to fill mine. This is what I'd use. The only affiliation with this company is the Great State of Michigan. http://www.rimguard.biz
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 01-29-2018, 09:34 PM
It doesn't take any more HP to turn a loaded tire as a not loaded one. (Ok... so maybe a VERY small amount, but none that will even be noticed, or easily measured.) I use CaCL2 because it's heavier. People say it rots rims. Only does if it leaks. WWF will too. It is a liquid and can cause rust. I have CaCL2 in some of my tires, have had for years. Not cheaper than WWF, but a lot heavier.
Load em up!
Old 01-30-2018, 05:44 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Any time you add weight to an object, it takes more power to move it up a hill.
Even given that, the gearing and torque of the 7HP will be more than up to the task.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-30-2018, 07:39 PM
Well yes, but the fluid doesn't itself take HP to move. It's different than towing the same weight, it's also different than weight on the chassis, as the weight goes directly to the ground. The chassis doesn't carry it. It also doesn't add rotational weight, like a wheel weight, as the fluid doesn't rotate. It simply just adds more weight to the ground. Best type of weight IMHO. Unless you are tractor pulling. Then you want wheel weights for the rotational force.
Old 01-30-2018, 08:34 PM
jbrewer's Avatar
Whether the fluid rotates or not, it takes power to lug it uphill, it takes power to accelerate it from rest to motion etc. Not as much as getting it to motion AND accelerating it rotationally (as in wheel weights), that's true.
Jake was questioning operation on a hilly area. have the same issue. Lacking in good sense, I just bought a tractor for the wheel weights :-) .
I may well add fluid as well. I don't have a level spot on my property and I can count on losing traction in several areas when mowing
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 01-30-2018, 08:44 PM
It's not enough weight to even begin to cause issue. It rolls easy.
Tags
7hp, cub cadet 72, fluid, rear tires, traction
