Old 11-06-2017, 02:15 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default Hydraulic snow blower
I built myself another attachment for 1772, a hydraulic driven snow blower. I have been thinking about this for a while now and I finally got the chance when I was given a 42" craftsman blower for nothing. Started off by building a mounting frame with my quick attach set up. Next was figuring out what size motor to use. Quite a bit of math involved. I wound up with a .388 Cid motor and with all the pulleys, rpm, and psi being factored in i came up with 15 ftlbs of torque driving the blower. The motor runs off the kwik-way loader pump. I made a video with more explanation and it running. I still need to figure out how to run the chute from the seat. Will also be adding a master releif valve to the system in the event I jamb the blower.
https://youtu.be/J7ZhEJtRSAQ
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 11-06-2017, 02:25 PM
Terry C's Avatar
Terry C Terry C is offline
That’s awesome!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-06-2017, 02:52 PM
Cool, great for those big drifts.
You should put some wheels on it.
Up to 534 and counting...
Old 11-06-2017, 02:54 PM
mortten mortten is offline
OSHA doesn't approve of the belt guarding. Nice work
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 11-06-2017, 04:08 PM
That's pretty cool. I was thinking of doing the same thing when I get my loader done.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-06-2017, 04:18 PM
ken6x6's Avatar
I'll put an " experimental" decal on it. That way I don't have to follow the rules. Lol
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 11-06-2017, 04:22 PM
ken6x6's Avatar
That's a good idea. Might have to do that.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 11-06-2017, 05:36 PM
Nice Job.....very impressive.
Old 11-06-2017, 08:30 PM
Nice work as always Ken.
This is the pump I'm using on my loader if I ever get enough time to work on it. Looks like the same you are using as the motor.
https://www.northerntool.com/shop/to...9706_200329706
Old 11-06-2017, 08:49 PM
john hall's Avatar
You Yankees get to have all the fun! Seriously, that is rather nice looking. Now being the Southerner I am, I'll ask aren't snow blowers/throwers supposed to "float".
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
