Old 04-16-2017, 01:24 AM
gdheck's Avatar
gdheck gdheck is offline
Default 1782 starter problem
Has anyone else on here done the starter upgrade on a diesel and then the starter wouldn't engage the ring gear? The starter gear moves out just fine, but most times it won't engage the ring gear and it doesn't start turning until the drive is fully extended. If I turn the gear just a little by hand it will start. I admit that I bought a chinese starter instead of a Nippondenso.
What is everyone else's experience with the starter upgrade?
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 04-16-2017, 07:08 AM
I have the $80 el cheapo on my 882 and it works great. How old is yours?
Old 04-16-2017, 10:06 AM
Check the clearance of the teeth between the starter and the ring gear. You may have it just a bit too close to the ring gear. I had to fiddle with the starter on a 2182 Kubota WG600.
Old 04-16-2017, 10:20 AM
gdheck's Avatar
I'll have a look at it in a few minutes. I don't remember the bolt holes having any slop to them though. Did you have to slot one of them a little with a die grinder?
Old 04-16-2017, 10:31 AM
If memory serves and that's a big if, I think I used a pry bar to hold the starter as far away from the engine as possible and tightened the bolts.
Old 04-16-2017, 11:08 AM
Where did you buy your starter?
Up to 534 and counting...
Old 04-16-2017, 06:49 PM
gdheck's Avatar
Mine came from Ebay.
I can't move it enough to do any good, because of the alignment flange that goes into the hole in the mounting plate. I've got the mount off of the starter and I'm going to try turning some off just that side. If that doesn't do the trick, although not my first choice, I guess I'll just face it off flat.
If I knew a Nippondenso would be any better I would just get one of them. I went cheap when I did it, because I didn't know for sure it would work that well.
