Old 03-29-2017, 05:41 PM
hogfly hogfly is offline
Default 782 hydro fluid change
i recently got a 782 it has the cast rear end no drain valve or fill other than the plug got a new filter and rear gasket what the best way to get fluid back in it thanks kenny
Old 03-29-2017, 05:47 PM
Pull the rear cover.
Old 03-29-2017, 06:04 PM
The rear cover should have a plug in it, remove the plug and fill it through the hole until it starts to run out. A funnel with a piece of hose on it would be helpful.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-29-2017, 06:15 PM
i knew i had to pull cover but is the plug npt i thought about screwing a nipple a 90 turning the pipe up with a fill cup up high has anyone tried it holding a funnel and hose for 7 qts seems time consuming and messy thanks kenny
Old 03-29-2017, 06:19 PM
Terry C's Avatar
Terry C Terry C is offline
I use a 90. Works fine.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-29-2017, 06:21 PM
RLause's Avatar
RLause RLause is offline
You can remove the top cover and pour it in till it runs out of the plug hole if you have the fenders off.
Richard
Old 03-29-2017, 06:31 PM
is it 1/2" npt i was thinking a nipple a 90 another nipple and like a 1/2"x1 1/2 reducer thanks
Old 03-29-2017, 07:00 PM
Do not use 90 in a hydro.
Edit: My bad I didn't realize that you were talking about a 90 degree elbow. Thought you were talking about 90wt gear oil.
Old 03-29-2017, 07:11 PM
cubs-n-bxrs's Avatar
Focus Sam LOL
Old 03-29-2017, 07:14 PM
Focus Sam LOL
Kelly
It's been a long day dealing with family crap, I'm old and I need a cocktail, make that a few cocktails.
