Old 05-09-2010, 08:03 PM
roaf3 roaf3 is offline
Default Cub 124 New Wheels
Hi guys;
I blew out a wheel bearing this weekend. As I looked at the original wheels they both had pry marks and the collar for the bearings were bent. Long story short, new front wheels and bearings. The wheels still seem to have some slop mayby <1/8 lateral slide on the spindle. Is this normal. The new spindle on the left is the same play as the OEM spindle on the right. The bearings seated flush on the collar and the spindle bolts with one flat washer are the same as the parts diagram.
I hate to spend all of this money on new stuff only to have it wear out?!
I appreciate any thoughts....And yes I will post a picture soon.
Thanks to all who respond.
Cheers,
Roy
Old 05-09-2010, 09:02 PM
johncub7172's Avatar
Welcome to Only Cub Cadets! A picture is worth a thousand words! I'am not the expert, so I'll turn it over to them. In the mean time, I'll try to help ya with any info. I can share.
Old 05-09-2010, 09:04 PM
You can get some shim washers to take up some of the slop if you like, but that is pretty normal. There is no preload on the bearings or anything.
Old 05-09-2010, 09:11 PM
Originally Posted by roaf3 View Post
Hi guys;
Cheers,
Roy
Roy
Old 05-10-2010, 02:35 AM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 05-10-2010, 06:27 AM
Aroostook Aroostook is offline
Smile
As Matt says, 3/4" shim washers (I get them from Ace Hardware) on the INSIDE of the wheel.
