Old 11-05-2015, 06:20 AM
S. Burns S. Burns is offline
Default New to Cub Cadets
Thanks for letting me in. I have just acquired a cub 1810 that looks very nice. But it won't start every time. Seems like a fuel issue. It always has spark. I can use carb cleaner and starting fluid and it still won't pop off. But sometimes it will fire right up and run like a champ. I've always wanted a cub cadet. But this is starting to change my mind.
Old 11-05-2015, 07:32 AM
First, welcome to OCC.........
I assume you realize that Cub Cadet bought a Kohler M-18 for that model. Thus the issue you are having is with the Kohler Engine and NOT Cub Cadet.
Since the Kohler engine utilizes the M-18 with a magneto ignition, this has been found to be rather reliable, as far as endurance.
Don't know what you mean by "pop off"...
I would suggest, your issue has something to do with fuel delivery. A partially plugged fuel filter, bad fuel lines, vent, or fuel pump.
Old 11-05-2015, 02:48 PM
Have you done a compression test on the engine? Does the spark look strong or weak? Is the fuel pump working? Have you checked the oil to make sure its not full of gas?
Pap's 100
Restored 108
1211 Dual Stick
1050
Tags
1810, wont start
