Old 10-17-2015, 09:05 PM
ccollins0601 ccollins0601 is offline
Default Engine quit today, now no compression
After a lot of work this past spring (http://www.onlycubcadets.net/forum/s...ad.php?t=37565), my 1200 Kohler k301 has run great all summer. Mowing and leaf sweeping today, and after about an hour it started to sound funny, like it was revving fast. I shut it off and when I tried to start again it would turn over but not start. After I turn the key off it keeps spinning much longer than normal.
Did some googling to figure out what it might be. I took out the sparkplug, turned the key with my finger over the hole, no air pressure. I can turn the engine by hand more easily than usual.
Based on the symptoms it seems like a broken connecting rod. I'm hoping one of you will tell me it's something simpler . Thoughts? What are my options and what should I do next?
Old 10-17-2015, 09:08 PM
Pull the tin ( sheetmetal ) and the head to see if the piston moves.
Sorry but from what you described, it may be a broken connecting rod. If not, it'll be a good excuse to decarbon the head and piston.
It may be a stuck exhaust or intake valve.
Up to 534 and counting...
Old 10-17-2015, 09:16 PM
olds45512 olds45512 is online now
thats what i was thinking.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-17-2015, 09:40 PM
I can see the exhaust valve moving through the sparkplug hole. I just decarboned the head this spring as show in the linked thread. I'll have to pull the head again to see more.
Old 10-17-2015, 10:18 PM
You could also take the valve cower off and see what the valves are doing.
Old 10-17-2015, 10:44 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Is the piston moving?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-17-2015, 11:13 PM
I don't think so. How would I tell for sure?
Old 10-17-2015, 11:47 PM
TheSaturnV's Avatar
Put a pencil or dowel rod down into the spark plug hole and rotate the engine, if it doesn't move, piston's not moving.
Old 10-18-2015, 12:13 AM
Is the spark plug hole in an AQS head over the piston?
