Old 08-16-2015, 07:49 PM
damage41 damage41 is offline
Default 782 hydraulics
Are the hydraulic pumps interchangeable between a 682 and a 782?
Old 08-16-2015, 08:03 PM
No.........
Unless you mean the charge pump only, then yes.
Old 08-16-2015, 08:14 PM
I'm going to look at a 782 that the owner says won't move and I have what is left of a 682 sitting in the weeds.So I was hoping the parts will interchange if it is a serious problem.
Old 08-16-2015, 08:22 PM
IIRR 682 is not ported for hydraulic accessories
The 782 is, so some internal parts might be the same.
Usually the hydro's are pretty tough and it is common things that cause problems like sheared pin, plugged filter etc.
only occasionally do the internals cause problems.
Old 08-17-2015, 10:27 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
On one of my 682s that I acquired, it did not move forward only in reverse.
I took the relief valves out and struck them against a hard object on the nut end.
I then reinstalled them and the tractor moved both forward and reverse. It was a simple and cheap fix.
Brian
