Never done anything "real" with paint prep, what do you all suggest for preping bare metal? Self etch?epoxy? Specifically my SGT braces...
I have some variprime 615s and 616s(activator) that was given to me. Is this the right stuff to use? How about for the aluminum rear? I want, and am willing, to do this right. |
I would make sure it's clean of oil, dirt , moisture and rust. I wipe or spray down bare metal with acetone. I would stick to epoxy primer. It's very good primer. Works on steel or aluminum. Here's what I use at work.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Duponts Variprime is a very good product and will work for what your doing. It works on bare metal and aluminum.
Make sure you use a proper respirator when spraying just like all paint. Your health is very important!! Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
Also, you can paint right over variprime, I like to use it like a sealer over what I am painting.
It should have directions on the can on how much time to wait before putting on your color. I painted a fleet of concrete trucks one time with variprime and Imron. It would take a full 8 hours of painting to do one truck! Randy
Thanks for the suggestions, I ended up using Eastwood Chassis Black and associated primer. I have used it many times before with exceptional results, not sure how/why I didn't think of that before. I'll post some pics in my SGT thread later today of how they turned out. I think I'll save the Variprime for this winter when I redo the sheet metal for the 2182.
Jon |
