Old 09-06-2014, 06:56 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default Cub Cadet 126 Steering Wheel
Ive just about tried everything trying to get this steering wheel off but it just wont budge. Do you guys have any ideas?
I do have several pullers but they all risk the possibility of destroying the steering wheel.
Thanks! Any help is appreciated.
Old 09-06-2014, 07:08 PM
cubs-n-bxrs's Avatar
Try hitting the bottom side of the wheel spokes with a dead blow hammer or a piece of 2x4 or somthing of that nature. Them particular wheels are really tough to put a puller on because of the bottom being tapered down to a fine edge. Pullers really tear them up. Others have had luck putting there knees under the steering wheel and pushing up. Install nut back on threads making sure no shaft threads are exposed and tap on nut while pushing up with knees. Good luck
Old 09-06-2014, 07:16 PM
I have never had that method fail, the bigger the hammer,,,,,, ,,,,, the better.
4 pounds is a nice round number, but, I have used 8,,,,
You do not need to swing it like you are driving railroad spikes, just a firm, serious "tap",,,
Old 09-07-2014, 11:29 PM
jcsmith jcsmith is offline
Search "steering wheel puller " . On my 104 I used a harmonic balancer puller. I tapped the appropriate size hole , ( 2 holes ) in the metal part around the shaft. I had to drill and tap at a slight outward angle so the bolts would go thru the puller slots . Use the protective cap on the forcing screw so you don't mangle the shaft threads. Works great . I personally don't care to use the hammer method. Good luck.
Chris
If you go this route you will have to use some washers on the 2 pulling bolts, they are smaller than the slots on the puller.
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 09-08-2014, 12:01 AM
bolivier's Avatar
bolivier bolivier is offline
On stubborn wheels I get an 8' 2X4 and go get my wife. She stands in front of the cub and pry's up on the bottom of the wheel. Where you would hold it, not the center. Not too hard as to damage it. I install the factory nut as to leave it above the threads about an 1/8". Then I get a bolt that fits inside the shaft, stick a couple washers on it as to not damage the factory nut. Then as she is prying up on the wheel I strike the center bolt with my 3 lb sledge. I hit it about 5 times then rotate the wheel till the next spoke. I do this repeatedly until I turn the wheel all the way to one side. Then I turn it the other way until it won't turn any farther. Repeat until it comes off.
As a side note I just took the wheel off a 125 that had been sitting outside for 20 years. It took about 8-10 minutes of this process to get it off. I probably turned the wheels back and forth 3-4 times.
I've done this with about 3 wheels and have been successful on every one, and NEVER damage one of them.
Hope my explanation made sense.
Old 09-08-2014, 12:11 AM
Have you soaked it for a few days with good penetrating oil? P.B. or equivalent will help.
I also put a puller on and leave it for days, snugged down and giving the nut a whack a few times a day and an extra turn on the puller. Just be patient and eventually it will pop off. Hopefully
Old 09-08-2014, 12:18 AM
bolivier's Avatar
Exactly. If you try to rush, you will damage something.
Old 09-08-2014, 07:30 AM
I was able to get up underneath of the wheel with a puller and with some light tapping I finally was able to coax it off.
Old 09-08-2014, 08:33 AM
Originally Posted by Jonah Close View Post
I was able to get up underneath of the wheel and with some light tapping I was finally was able to coax it off.
Good to hear. in the future another good way to get a wheel off that's really stuck is to remove the nut and spray it with pb and then go now the grass, I've only every had to use that method once on a 122 wheel that just wouldn't come off but after an hour of mowing it popped right off.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-08-2014, 07:08 PM
IHinIN IHinIN is offline
I've heard of guys having luck using an air chisel with a round punch attachment to hit the loosened nut while putting upward pressure on the wheel with your knees.
