Old 09-03-2014, 04:09 PM
garnold's Avatar
garnold garnold is offline
Default Hardware Guide?
I must have miss placed the bolts that I need to re-attach the tunnel cover to my 108. Anyone know the size I should go and buy?
On another note, has anyone put together a hardware guide for replacing all the hardware on a tractor? Is this something we might all work together and create as a loving family Maybe something like this....
Item --- Size --- Model(s)
I'm sure most of these parts are the same across a lot of tractors so we could put something together that could help all of us out.
Old 09-03-2014, 04:15 PM
Gene,
the parts books specify the hardware needed.
Old 09-03-2014, 04:18 PM
I always run a tap into the holes (cover and frame) then install 1/4X20 bolts.
THAT will hold them!!
I got tired of dealing with rusty oversized holes.
Old 09-03-2014, 04:20 PM
The tunnel cover bolts are a odd size. They are #12-24 x 3/8".
Locally they are a tad hard to find. So.....I got upset with this whole fiasco, and I drilled & tapped mine for 1/4-20 x 1/2". Problem solved. A whole lot easier to find. Stainless Steel Hex or Phillips head suit me well.
Old 09-03-2014, 04:22 PM
c69ss396 c69ss396 is offline
I replaced every bolt, washer and lock washer with stainless, Unless you "know a guy" I wouldn't go that route but it sure does look good...
Old 09-03-2014, 04:26 PM
The little man on the tractor likes company, many little men and tractors
Old 09-03-2014, 04:41 PM
garnold's Avatar
Good deal guys, and thank you!
Old 09-03-2014, 04:48 PM
o---o o---o is offline
Hmmm this explains why the 1/4-20 bolts I tried to put in didn't work, thanks for the good post!
Old 09-03-2014, 04:50 PM
garnold's Avatar
So is that what you guys do with most of the bolts on these tractor's? Drill and tap as many of the ones you can to 1/4x20? That really does make a lot of sense. How much of the tractor can you convert over and are there many areas that still need strange sizes?
Old 09-03-2014, 04:52 PM
cubby102's Avatar
cubby102 cubby102 is offline
Ive been thinking of doing this exact thing when I tear down the 1200 to give it a freshen up
