Old 06-26-2014, 09:20 AM
dbuck dbuck is offline
Smile Mule Drive Spacer
While rebuilding my mule drive, I have seem to lost the spacer that goes with the idler adjuster on the mule drive for my 149. The PN: 545687-R1 is NLA. Could someone give the depth so I can machine one? Or maybe someone has an extra I can buy? Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 06-26-2014, 10:03 AM
Don
That spacer is no big deal. All you need is a bushing with an OD that will slip through the idler adjusting bracket that is slightly longer than the thickness of the bracket. It needs a 3/8" ID for the bolt that goes through the pulley.
Old 06-27-2014, 08:16 AM
Smile
Don
Thank you for your reply. Where did you find that breakdown?
Old 06-27-2014, 08:42 AM
Don
It's from the 1A tiller manual
http://ccmanuals.info/pdf/1A%20Tille...s%20Manual.pdf
Old 06-28-2014, 04:44 AM
Smile
Thank you, Mr. Sam Mac. I am pondering the idea of, eliminating the tension spring and going with adding the adjusting rod in place of the spring. Any thoughs on this idea?
Old 06-28-2014, 06:03 AM
Don
That's how I have my tiller setup. No spring.
Old 06-28-2014, 08:22 AM
c69ss396 c69ss396 is offline
The pre 1968 mule drives I didn't use a spring anyway.....
Old 06-29-2014, 06:29 AM
Smile
Don
Having sold my tiller. The change from spring to adjusting rod will be used with my mowing deck.
Old 06-29-2014, 06:32 AM
Smile
Did not know that. Thank you for the info.
