Old 09-12-2013, 01:14 PM
OldAndInTheWay's Avatar
Default What do the wise folks here think of the Cub Cadet 682?
I have my eye on a 682. I believe it has a twin cylinder Kohler in it. Are the twins good and are they easy to work on?
The red intrigues me.
Old 09-12-2013, 02:12 PM
The 682 is a manual lift. They came with the KT17's. Check if its a series 1 or 2 engine. The series 1's had their problems being that they were splashed lube and if mowing a lot of hills on its side it would starve the rod oil and bang!
Other then that the 82 series are nice tractors and fairly easy to work on.
Old 09-12-2013, 07:05 PM
Other than Diesel Supers, my favorite cubs are the 82 series models. The 682 is a great model. As mentioned it has manual deck and attachment lift whereas the 782 came with hydraulic lift. If you don't plan on using plows or heavy attachments, you will be fine. You can install a lift spring to help lifter heavier equipment, but it will still work you to death, this is simply based on my own personal experience, it may not apply to you.
Old 09-12-2013, 09:02 PM
Redblower's Avatar
Redblower Redblower is offline
I'm a newbie here, because I just picked up a 682, says series II on the air cleaner, also, had a 147 years ago but no need for a tractor for a long time, finally got tired of walking behind the snow blower in these norther Michigan winters, getting too old for that stuff!
So really was luck of the draw that I ended up with this, of course now that I have it I'm getting all geeked about getting a 3 pt for it and dream of hydraulics!
These guys have already been a big help, love this place and I hope we enjoy these red tractors.
Old 09-12-2013, 09:43 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
I've got a 682 with the Series I engine, and a 782 with the Series II. Both are great machines. As said before the Series I engine had serious oil lubrication problems corrected with the Series II. So if you would be using the 682 on relatively flat land, and not operated for extended time (say under a minute) on a slope, I think you will like the 682.
Personally I like the electrical PTO and forward/reverse control of the 82 series over the 1X9 series.
Old 09-14-2013, 09:11 PM
jeepchicken5000's Avatar
I have a 81 682 with the series one engine and its fine so far and I have a little bit of a hill, I don't have much worries but I have some valve noise so ill need to look at that sometime
1981 cub cadet 682
1966 cub cadet 122
Old 09-14-2013, 09:43 PM
Let us know when you procure it so you can get some photos out to us.
Old 09-14-2013, 09:51 PM
jimbob200521's Avatar
I've got a 682 with a Series I engine (early serial number at that) and haven't had any problem with it. I avoid hills like the plague but that's just my obsessive paranoia Anywho, it's my favorite series of Cubs (followed by the mid 90's Supers and the 1x9 series). Last ones IH made, SOLID construction, lots of options, tons of power, and just plain sexy. Keep plenty of oil in it, avoid hills, and you should be just fine. Good luck, and be sure to post pics!
-Ryan
