#31
Hey! How come no body told me which way the cradle mounts to the engine, lol! See in the first page the cradle is on backwards. Corrected that, and pictured the left side of the cleaned up K301 here:
What's what about the electric clutch? My 1250 has one and I was wanting to know if those can be rebuilt...............?
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#32
Also, I have a .250" x 2" flat stock piece of steel for the cradle mod. { the cradle measures .237" } I was looking up a ignition switch tonight and part# IH-61524-c3 is called a 4 prong switch fitting a 1250. Looked up the wire diagram and it shows a 5 prong switch like so pictured here:
And the wire mess here shows a 5 prong plug. Are these components correct for a 1250? I'm confused then, by a 4 prong and what I'm looking at thinking its a 5 prong on the tractor.
#33
Keep the pics and updates coming, John!
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
#34
spark plug should be gaped at .035" .
What gap should I set the points to? I believe I went .020" {battery} I have identified this Kohler K301 to have a Electric Start 15 Amp Regulated Battery Charging System. Kohler Adjustable Jet carb Preliminary Settings: low idle: 2.5 turns high idle: 2 turns
#35
4 prong key switch is right
#36
Thank you Ray.
Here is the wire diagram for a 1250. Time to re-wire this tractor!
#37
I'm just kidding.
#38
How I figured that out was when I went to make a 8 3/4" x 2" x 1/4" flat steel template for the engine cradle mod. Some thing just was not " lining up-right " , lol! Just cant wait to start this 1250. But until I can fund the 1250 I will be gathering all important information about it. The 72 is the bread winner and comes first
#40
Thanks cubfan, wish we could save em all.. Keep up the good work John! Been watch'n this closely.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
Thread Tools | |
Display Modes | |
