Old 03-17-2013, 12:28 PM
gdheck's Avatar
gdheck gdheck is offline
Default Will a drive cup with pulley work on a 1200?
I have a 1200 that I want to add a pulley to the back of the engine. Will a drive cup with a pulley from something like a 122 work for this and allow me to still use the correct screen and clutch assy. for the 1200?
I already know that I will have to set the clutch back the same amount as the new drive cup adds and shorten the driveshaft.
Thanks
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 03-17-2013, 12:52 PM
Muzzy Muzzy is offline
I did something similar on my 147 to run a hydro lift pump. I had to cut the cup off and only used the pulley. I shortened the driveshaft to account for the thickness of the pulley and got longer bolts and bolted the pulley and driveshaft hub to the drive cup as you normally would. I'm not familiar with the 1200 so, I can't say if what I did will work But, it worked great on the 147.
