Old 12-16-2012, 08:01 PM
Default Forgive me if this has been asked before, but...
I've got a question about the hydro on my 147. When going from forward to reverse I can notice a slight thump and I have visually seen the pump moving forward and reverse respectively. Is this due to the pump being loose, and if so, how does one go about tightening it?
Thanks
Old 12-16-2012, 08:14 PM
Thanks
You better take a look at the bolts that hold the rear in the frame. Even the cast iron rears get loose.
Old 12-16-2012, 08:38 PM
never thought of that... I thought it might be the cap screws that hold the pump to the rear end...
Would the bolts that hold the rear in the frame be those that are needed to be removed when the tractor is involved in a split? (I've got the service manual and I think I know which ones you are referring to)
thanks
Old 12-16-2012, 10:00 PM
Those are the ones, also there is a bracket on each side that attaches the the tranny and the frame.
Up to 534 and counting...
Old 12-17-2012, 09:09 AM
I had them get loose on the 1650.
Old 12-17-2012, 12:45 PM
I looked at my (cubs) rear end today; three of the 6 cap screws were loose. The one on the front of the rear end (the one that is centered between the 3 that are needed for a split) were the worst. The one on the left side (looking forward) was so loose I could take it out with fingers.
Never would have thought to look there. I figured I had bigger fish to fry. She works MUCH better now, very smooth.
I appreciate the tips on where to look. I'm thankful for this forum and the people on it. Thanks a lot!
Old 12-17-2012, 12:46 PM
I'm glad it was a easy fix for ya!
Old 12-17-2012, 01:10 PM
Glad to hear you fixed it!
Old 12-17-2012, 01:53 PM
teejk teejk is offline
I've got mine split at the moment on a 1250 waiting for parts...2 of the 6 bolts were "gone" (one on the right side pumpkin, one on the left side L bracket)...probably has been the case since before I bought it but I never noticed. maybe explains why the donuts are shot and the cooling fan has been nubs since I've owned it (will finally be replaced now that I understand things).
Should some type of "locktight" be used on the rebuild? And as long as I'm on the subject, why does that stuff cost so much?
Old 12-17-2012, 02:59 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Probably since there are not too many of the cub cadets left (except at Sam's and Allen's houses)!
John
