Old 02-24-2012, 06:27 AM
maddog784's Avatar
Default Hydro Transmission Questions
I was told that there is a difference between the transmissions for a 982 and a 782. What is the difference here? Is it a different hydraulic motor? The only differences I saw were the hydraulic motor and the brake assemblies. If the only difference is the hydraulic motor, what makes them different? Are they interchangeable?
Thanks in advance,
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 02-24-2012, 06:46 AM
YES....there is a difference. It is in the output shafts. See attachment....
Old 02-24-2012, 07:10 AM
The output shaft of the hydro pump is different, but that's not what Roland posted a picture of. The hydro output shaft has one less tooth on a 982, and consequently the driven reduction gear is larger. You cannot interchange the pumps on a rearend without changing the driven reduction gear to whichever one belongs with the pump you are using. Also, the 982 pump has a splined input shaft.
Roland's picture is of two pinion shafts, with the one on the left being from a cast iron rearend, and the one on the right from an aluminum rearend, which could be either out of a 982 or 782 or something else...it doesn't matter, because the pinion shaft is not different between a 782 and 982, provided both have either a CI rear or both have an aluminum rear.
Old 02-24-2012, 08:13 AM
maddog784's Avatar
So would the reduction gear from an aluminum rear fit on the pinion shaft from a CI rear? The fact that the input splines on the pinion shaft are the same and that the pinion shafts are the same part number leads me to believe they are the same. Is this correct?
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 02-24-2012, 08:46 AM
There were three (3) basic Hydro units that IH bought from Sundstrand
* 717-3032 Non Ported
* 717-3033 Ported
* 717-3034 High Capacity SGT
There is a difference between the 717-3034 (SGT) and the 717-3033. IIRC correctly, it is two fold. Different output shafts and they label 717-3034 as "high capacity".
Matt:
How do you explain, that for example, the 782, that the Hydro Unit for the Cast Iron Rear and Aluminum Rear is the SAME (717-3033) per the Parts Manual.
Old 02-24-2012, 12:05 PM
maddog784's Avatar
What about a 1450/1650 rear? The parts comparisons look like the only differences are:
- Reduction gear would have to be changed to the 68-tooth
- Hydro pump from the super (3034) would have to be used instead of standard (3033)
It looks like the bevel pinion shaft input splines are all the same. Looks like any reduction gear will fit on any bevel pinon shaft - is this correct?
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 02-24-2012, 02:20 PM
jbollis's Avatar
jbollis jbollis is offline
The hydro units are the same in all of them except. First it being ported or not, and even the ported "plugged" ones can be converted to a full ported pump.
And that the "super " pumps have a spline input shaft, and a different tooth count on the output shaft. The output shaft of the super will only mesh with the reduction gear from a super and the same goes for the "regular" non super pumps. The reduction gear has a splined hole in it that will fit any pinion shaft. The only difference in pinion shafts is whether they are straight cut or angle cut. This also will play a part in what ring gear, carrier , and axles you use.
Sold everything but one.
Old 02-24-2012, 03:01 PM
maddog784's Avatar
But if I don't change any ring gears or axles, I should just be able to switch the reduction gear, use a super pump, and everything will work out fine, right?
Nate
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 02-24-2012, 03:02 PM
jbollis's Avatar
Nate
Yes, what exactly are you trying to accomplish ?
Old 02-24-2012, 03:36 PM
maddog784's Avatar
I am trying to find a cast iron rear for my super and am wanting to know if a few modifications to a standard cast iron rear from a 1450, 1650, 782 would suffice if I switch the reduction gear and hydro drive motor.
Thoughts or comments? Most importantly, will it work?
Nate
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
