Has anybody added a charge warning light to a S/G equipped Cub Cadet?
This sounds like a good way to monitor the charging of a tractor when you are too busy watching where you are going to look/analyze an ammeter! I saw this in an off brand tractor manual, sounds like a good addition to a Cub!! GENERATOR WARNING LAMP Inspection The generator warning lamp is connected between the generator (G) terminal of the voltage regulator and the light, (A) on ignition switches with 4 pins, and terminal (L) terminal of the ignition switch with 5 pins. If the generator output is at a higher voltage than the battery, no current flows through the lamp and it remains extinguished. If the generator output is at a lower voltage than the battery, current flows through the lamp and causes it to illuminate. To check the generator warning lamp, disconnect the wire from its terminal on the lamp. Then use a multimeter to check the resistance across the lamp terminals. Begin with the red (+) multimeter lead on the terminal where the wire was connected and the black (-) lead of the multimeter on the other lamp terminal. The resistance in this direction should be high (500 ohms or higher). Then reverse the multimeter leads on the lamp terminal. The resistance in this direction should be much lower. If not, the generator lamp is bad and should be replaced. ![]() Since my only operating Cubs do not have a S/G, I can not be the guinea pig. Anybody care to try this? sounds simple, just add a light bulb!! |
You could also probably put a Green LED across the ammeter with a series current limiting resistor...say.... 1K resistor. If the green light is on, current is flowing from the S/G to the battery and you're good!
BAT side of Ammeter-----|<---/\/\/\-------- S/G side Any old LED will work. 1K resistor, half watt size . John
You could put a red LED pointing the other way in parallel with the Ammeter (and the green led/series resistor) indicating a discharge.
Batt side of ammeter S/G side o------------->|--/\/\/\--------------------o ( red LED 1K res) o-------------|<---/\/\/\--------------------o Green 1K
Is it really that difficult to look at the ammeter and see which direction the needle is pointing?
![]() Quote:
And snow blade work is done at night a lot, with too many lights on, another reason to need a warning light. Mowing the grass, yea, check the ammeter every hour!! |
![]() Quote:
Radio Shack is going to get a few bucks$$$!! |
PM or email me your address and I'll send you some ....
![]() Quote:
I not big on cutting/modifing the wire harness under the dash. Adding gagets like extra lights is a accident waiting to happen. |
![]() Quote:
A light will catch my eye, a slight movement of a needle will not. My tractors are in BIG trouble!! DSC_0087640x380.jpg But, my mods are my fun!! |
![]() Quote:
