Old 01-12-2012, 08:17 AM
Default Discs' or Internal Brakes? How do I Choose?
You have 2 QL gear drive tractors setting in front of you.
One with internal brakes, the other with discs.
Which one do you choose?
Each must have their good and bad points.
I am leaning towards the discs because the disc brakes will stop on a grade better if one rear wheel looses traction. (I have hills)
The discs do not require transmission removal to service the brakes.
Am I missing something??
Could discs be added to the internal brake tractor for better braking? (Use both systems)
At my age I like stopping as much as going!! Please help me choose!!
Old 01-12-2012, 08:34 AM
gcbailey's Avatar
gcbailey gcbailey is offline
the only thing about disc, or internal for that fact, if the tractor doesn't weigh enough to stop, it will just skid. A legitimate 30 yard skid down a 35 degree slope while trying to disengage the deck isn't that fun. Then I added weights!
but discs do give me that "warm, fuzzy feeling" for what it's worth....
Gary
Old 01-12-2012, 08:40 AM
Vince_o Vince_o is offline
The answer is simple, they are both QL's, SCRAP THEM!
I prefer internal
Old 01-12-2012, 08:46 AM
With the external if they build up a little rust or get to wet it takes a sec for them to grab a hold the first time you go to use them. BTDT The internal do not have that problem.
It's a cub save them!
Old 01-12-2012, 09:20 AM
I concur with Vince,wet brakes do stop both wheels not just one.
Up to 530 and counting...
Old 01-12-2012, 09:41 AM
I would think that the differential would allow internal brakes to fail to slow/stop the machine if one rear wheel looses traction.
This is a severe circumstance, one that occurs if you have a loader or if a trailer load of firewood is pushing you down a grade.
Won't the differential will allow the low traction tire to counter-rotate, eliminating the braking effort of the internal brake?
Isn't the internal brake similar to depending on engine braking?
The reason I am asking is that I have never used an internal brake Cub Cadet, but the 448 Case with a band brake I had for a short while was a braking nightmare!!
Old 01-12-2012, 10:39 AM
cub123's Avatar
cub123 cub123 is offline
CADplans: you are right, if you get it on a hill one wheel will spin backwards and the other will just roll, though the discs will stop both it may want to go sideways. Thus, the only real way to stop a cub on a hill is to add more weight to the rear. In this case the discs would still be the better choice if they are adjusted and work even.
Old 01-12-2012, 05:57 PM
Just slam it in reverse and hope for the best. With the internal brake you can put wheel weights on the inside and outside of the rim. I like the external brakes but then again I'm pretty much all flat where I live.
Old 01-12-2012, 07:02 PM
vbob01 vbob01 is offline
If you decide to listen to Vince, let me know and I will take care of them for you.
Bob.
2550 with sleeve hitch
1250 with tiller, blade, deck
826 snowblower
Past machines 72,1650
Old 01-12-2012, 08:23 PM
gcbailey's Avatar
I say just change your mindset, live with the mentality "brakes! we don't need no stinking brakes!"
Gary
