Old 01-04-2012, 01:03 AM
GERKS 149 GERKS 149 is offline
Default Rim width
Can anyone explain the different rim widths? I am confused! My 149 appears to have the narrower 8 1/2 inch rim with the 23x 10.5 tires. Since my Dad was original owner on this tractor, I feel this is the original rim and tire. The tires are the Firestone turf tire with the zig-zag snow tire pattern.
Now I purchased a set of tires and rims with the 23x 10.5 tires and the rims are the wider 10 1/2 inch ones. The tires are the Goodyear turf tires like the ones on my 1250. I was under the impression that the narrower rim was used for the 23x 8.5 tires and the wider rim was used for the 23x 10.5 tires.
Old 01-04-2012, 06:02 AM
72-149's Avatar
72-149 72-149 is offline
the 8 1/2 wide rims are factory on the 10.50 tires for the 149 & are consiterd wide rims,the 8.50 tire got the 7" rim,some one put those 10 1/2 wide rims on the 1250,10 1/2 rims were on some of the supers with 26x12x12 tires.heres a chart from the site hope this helped
Old 01-04-2012, 06:09 AM
Gerks:
Click here and scroll to the bottom.......... Rims
Old 01-04-2012, 09:12 AM
Thanks a lot. That sure help out.
Old 01-04-2012, 10:15 AM
Sorry I am not right on my rim widths. I went back to take a look at these. My 149 has 7 inch rims I think. Do you measure the total rim width or the inner dimension that the bead seals on? When I measure this bead area, it is approx. 7 1/4 and total rim width is 7 3/4.
Now the other wider rims are the 8 1/2's. The 149 had these narrower rims on it originally with the Firestone 23x 10.5's.
Old 01-04-2012, 10:28 AM
72-149's Avatar
If you have a tire on the rim it is easier to stick the tape measure through the rim & measure from lip to lip like I have marked in pic
