Old 11-23-2011, 02:13 PM
SwampRatt-1977's Avatar
Default Special Tool?
im pulling apart my poeted 1650 pump and got to the swashplate on top. i saw the two roll pins and started pounding it through little did i know it went half way then hit the aluminum case. my questiong is, is there a special tool or something. how do you take #52 out of #10 without need a access hole in tha case? drill out the pins??.
Thanks
-Randy
Old 11-23-2011, 02:48 PM
jbollis's Avatar
jbollis jbollis is offline
When I took mine apart I found an online service manual.
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
I believe it starts down around page 60 or so.
If I remember correctly it addresses this issue in it.
on mine there were 2 short pins stacked on top of each other in each side. When looking down at the assembly, with the swash plate straight (horizontally), you should be able to pound the "top" pin until the "bottom" pin is loose enough to get out by tipping the swash plate. Then the top pin will be centered in the trunnion shaft. Be careful not to pound the pins to far as it will jam against the case, making it really hard to get the first pin out.
Here is a link to the thread I made when I took mine apart.
http://www.onlycubcadets.net/forum/s...ead.php?t=4958
Sold everything but one.
Old 11-23-2011, 03:44 PM
You need to read and completely understand the disassembly procedure in the service manual that jbollis posted, for the very reason you've just discovered, if nothing else, before you go any further. There are several steps that you have to do correctly or you'll destroy the pump either taking it apart or reassembling it.
Old 11-23-2011, 06:30 PM
thanks guys, i got it apart.
