Old 10-21-2011, 12:58 AM
ihnick's Avatar
ihnick ihnick is offline
Default crankshafts
Are the 12 or 14 horse cranks the same as a 16 horse? or is a k341aqs crank the same as the k341 that's in my 169?
Nick.
Old 10-22-2011, 12:03 PM
samiam44 samiam44 is offline
Yes the 14 and 16 hp K's have the same crank- I think only the 10hp is different. You can verify using the online CC parts catalog.
You can also use a Magnum crank off a M14 or M16. The magnum's are nodular iron instead of just cast. So, they are a bit stronger.
Any used crank make sure it's straight and check it closely for cracks in the radius @ the rod. Dye pen or traditional magnaflux work well.
Remember I think the output shaft configuration is unique to cub's.
Michael
