Old 09-17-2011, 02:15 PM
BinderRod's Avatar
BinderRod BinderRod is offline
Default Working out the bugs on my 149
I got the starter problems taken car of. It wound up being a bad battery. Now time to put friction washers on the hydrastatic linkage. It just wants to flop around and makes for some interesting speed control while trying to hold the lever steady. I also has a leaking front tire. I put anti freeze in the tire and put the air to it and it's good as new. If it ever stops raining I will get some pictures. I have been told you guys like pictures.
Never enough time, tools or money
Old 09-17-2011, 03:25 PM
westofb's Avatar
westofb westofb is offline
Welcome and congrats on your 149. You talk about changes in speed, it may need attention in the trunnion area, the springs get weak, the slot they ride in gets worn spots, and the cams themselves get worn and sloppy. Any and all these conditions could result in undesired changes in speed, I am guessing the sloppy control handle is just the tip of the iceberg, but don't get
discourage, all the problem areas I mentioned are repairable. Do some looking around, search the site, ask questions, that is what this place is all about, helping one another keeping the cubs up and running/ working strong.
I have a 149 that I am almost done rebuilding from the ground up, the thread is entitled, "Cub 149 Resto-mod",'you will find it right here in this section, you mind find some items, repairs, and upgrades listed in it that could be useful. I had to perform the repairs mentioned on my trunion as well, they are listed there.
Good luck, you'll love your new workhorse!
Oh by the way, I never heard of using antifreeze as a remedy for a leaky tire....interesting!
Jeff
Brookfield, MO
________________
Old 09-17-2011, 08:19 PM
BinderRod
Glad to hear you are making headway on the 149.
And yes we love pictures
Old 09-17-2011, 10:56 PM
Oh yeah, we love pics. Bring them on!
Old 09-17-2011, 11:24 PM
scleve scleve is offline
Good luck! It will be worth it in the long run.
Old 09-18-2011, 12:28 AM
Oh yeah we love the pics!
Old 09-18-2011, 09:26 AM
BinderRod's Avatar
I found that the friction disc were shot. Seems like a real easy fix. I wish it would stop raining so I could play
Old 09-18-2011, 09:51 AM
LarryW's Avatar
LarryW LarryW is offline
When I was a kid I tried water and it works to. That was before green slime. I have also used used motor oil. It sometimes even works for dry cracks. I think the fluid washes small debris into the holes. And being fluid it leaks slower until the debris can find it or maybe the air leaks just blow it through? I dont know for sure, all I know is sometimes its a cheap fix!
BinderRod, Is it still raining? lol I want to see it!
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
