Old 08-23-2011, 05:10 PM
roaf3 roaf3 is offline
Default Plow Project on 124
Now that I have a proper diagram (thank you members)
I am trying to find some chains.
I ordered 1/4 inch steel spacers for clearance
I need to find the exact lugs for the wheels
just 1/4 longer.
Does anyone have sources for lugs or size
and thread?
I am also hoping the chains will run
on the Carlyle Ag tires that I have on
it.
Thoughts or suggestions are appreciated!
Cheers,
Roy
Old 08-23-2011, 06:57 PM
I think the lug bolts are 7/16" NF, but why do you need spacers? I have never needed wheel spacers to use chains on any of the Cubs I've had.
Old 08-23-2011, 07:29 PM
I had to upsize my chains to fit my Carlisle 10.5's because the normal chains for the turfs that size came up short. If your lug tires have deep bars, then i suggest you scale up your tire chain size to accomodate the larger tires.
Old 08-23-2011, 09:32 PM
CaptMax's Avatar
CaptMax CaptMax is offline
What size chains did you end up using for the 10.5's?
CaptMax
Old 08-25-2011, 06:44 PM
I have the same setup as Capt Max. -Very nice rig btw!
It seems because of the rear tires and chains that a 1/4 of space would help the chain aspect of it.
I would love to know the chain size that fit.
Cheers,
Roy
Old 08-25-2011, 06:59 PM
If you have the correct rims and keep the chains tight, you do not need spacers.
Old 08-25-2011, 10:08 PM
westofb's Avatar
westofb westofb is offline
I think if I were you, find an old set of turfs for the chains, they work better with chains anyway, keeping more of the chain in contact with the ground. With ags, the chains will try to slip between the lugs and therefore not contact the surface you are driving over. An old set of weather beaten turfs with an extra set of wheels would do the trick, even if you need to tube them to keep them inflated. Save your ags for summer use.
Jeff
Brookfield, MO
________________
