Old 08-03-2011, 10:57 PM
johncub7172's Avatar
Default CC71 Brake adjustment
I need to stop as good as I go. With 50# wheelweights I'am not stopping when I back down the ramps of the Cub shop. As I understand the Blue Ribbon Service manual, adjust the brake adjusting screw "IN" to make up for slack. So my question is: If the adjusting screw is touching the lock nut, is it time to replace/re-line the Brake lining disc? I think I have about 1 inch to go before the two meet. I do have some brake, more so on flat ground, but not on any incline. Never made any brake adjustments to a CC before, so I wanted to ask the Pros.! Thanks, John
Old 08-03-2011, 11:06 PM
scleve scleve is offline
Are you saying you have an inch of thread showing?
Old 08-03-2011, 11:08 PM
I would like to say so. I do have some thread before the head of the adjusting screw meets the lock nut.
Old 08-03-2011, 11:09 PM
Donovan M.'s Avatar
take the nut and losen it so theres like a 1/4 in gap and tightion the screw in the middle so theres like an 1/8 in. play that should solve your brake problem.
Donovan:
62' Original-fenders
Old 08-03-2011, 11:35 PM
Don't forget to lock down your locknut.
Old 08-03-2011, 11:38 PM
Thank you Donovan M. I was looking for that figure. For some reason, I lost contact with OCC. I need to make up brake due to the added weight. Because "in or out as required" has me guessing with the wheelweight factor!
Old 08-04-2011, 01:06 AM
TEET's Avatar
TEET TEET is offline
John, I just did this adjustment on my 102, and it really doesn't take much turning of the screw to give you more brake. I was to the floor with my 102, and a quarter turn made a huge difference! Good luck!
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 08-04-2011, 01:52 AM
Teet- I do have 8.5's { turff} rear, and 6.5's {5-rib} front which it rolls more so. I'am sorta on a hill side.
Old 08-05-2011, 10:00 AM
I now have good brake! Jeff- your right, I only needed about 1/4 turn. May need to back it off some more after I run the tractor around a bit. Thanks guys! -John
