Greg Rozar AKA- CubDieselFan
Old 09-02-2018, 05:12 PM
Jmacsellnu Jmacsellnu is offline
Angry Blowing fuse turning key
I have a LT1050 and while cutting(literally the last row) it died. I saw the fuse blew and every time I put a new one in, it blows as soon as I turn the key. I have checked all connectors visually and seem ok. I have checked the ground and looks to be ok. Any suggestions would be greatly appreciated! I’m not great with diagnosing shorts with meter. I Have taken the deck off unplugged the PTO, and any other plugs individually and it still blows instantly! New battery also.
Old 09-02-2018, 05:21 PM
cooperino's Avatar
Originally Posted by Jmacsellnu View Post
I have a LT1050 and while cutting(literally the last row) it died. I saw the fuse blew and every tine I put a new one in it blows as soon as I turn the key. I have checked all connectors visually and seem ok. I have checked the ground and looks to be ok. Any suggestions would be greatly appreciated! I’m not great with diagnosing shorts with meter. I Have taken the deck off unplugged the PTO, and any other plugs individually and it still blows instantly! New battery also.
Could be a short in the keyswitch or harness. Not knowing your particular tractor. Is the back of the keyswitch screws on wire connectors or a plug?
Old 09-02-2018, 05:31 PM
The key switch is plug in.
Old 09-02-2018, 06:03 PM
Unplug headlight circuit. Also do you have anti backfire solenoid on bottom of carb? Both energized from same circuit of kys.
Old 09-02-2018, 06:22 PM
Not sure about the solenoid but i will try to unplug from the headlights and try and also look on the bottom of the carb.
Old 09-02-2018, 07:42 PM
I'd look for rubbed wires. Solenoids and lights seldom blow fuses. It's rare.
You need to know what year tractor you have, then you can get a copy of the wiring diagram here:
https://www.cubcadetpartsnmore.com/c...ing-schematics
Old 09-02-2018, 09:18 PM
dale c. dale c. is offline
I worked on 1 similar to yours and found a bad headlight bulb that the filament had blown and was touching the base of the bulb making a short and blowing the fuse
Old 09-02-2018, 09:22 PM
I've seen that before also, and is possible. But it doesn't happen often. Definitely something to check.
Old 09-02-2018, 10:07 PM
Were do you find the year of the mower? Now that i think of it my headlights are burnt out so i will check that for sure tomorrow. I tried tracing the wires but didn’t see anything.
Old 09-02-2018, 10:45 PM
Look on the serial number tag. I doubt it's printed on it, but may be. The wiring diagrams have a harness number on them. Or at least the one I downloaded did. Maybe you can find the harness number on yours.
Tags
fuse blowing
