Greg Rozar AKA- CubDieselFan
Old 01-28-2019, 07:15 AM
gulflex1 gulflex1 is offline
Default Ross Steering Box Socket
I don’t know what you guys use on the nut on the bottom of the Ross Steering box, but I have found it difficult, because even my widest screwdriver is not wide enough to turn it without messing up the slot. I took an old socket to my welder buddy and had him weld a plate onto it, so now I have a socket to use on my ratchet wrench. I hope that someone else can use this idea to simplify their process!! (Wasn't sure which area to put this in)
David
North Carolina
Old 01-28-2019, 07:43 AM
cubs-n-bxrs's Avatar
I use a drag link socket.
Old 01-28-2019, 08:14 AM
Scrap of flat bar stock and a vice grip, or a flat washer ground off on one edge.
I have never ran across one that didn't turn out easily though.
mostly use the tool to seat the bearings for initial adjustment.
Old 01-28-2019, 10:23 AM
DieselDoctor's Avatar
Good homemade tools are a lifesaver. As mentioned above, a drag link socket is the tool you would need to buy if you couldn't make something. Here's what they look like ---
https://www.zoro.com/proto-drag-link...CABEgLjePD_BwE
