Greg Rozar AKA- CubDieselFan
Old 10-03-2018, 06:32 PM
TexasP TexasP is offline
First, thanks for every ones input.
Yes I am aware of the double screws. I got the other sides out, but ran into this on the opposite sides top screw. It was a PROTO ease out and I'm not sure what type of bit; didn't hold up well to the PROTO though.
Old 10-03-2018, 06:54 PM
cooperino's Avatar
Most drill bits will not fair well against an easy out. If you have a dremel, get a grinding bit with long shaft. Grind out the easy out and make a hole for another easy out. take your time!
Old 10-03-2018, 07:53 PM
If he has a bit stout enough to grind out an easy-out, just grind out the set screw too. That's way easier than breaking another easy out.
Old 10-03-2018, 08:12 PM
Good deal. I will give the dremel grinder a shot. Thanks y'all.
Old 10-03-2018, 09:33 PM
cooperino's Avatar
Yup. Go slow with it. Once you get the old extractor out soak it good for a day or two. Then use a good quality easy out.
Old 10-04-2018, 12:30 PM
FYI....deleted 11 postings of unwanted bantor.
Roland Bedell
Buy: Made in the USA
Old 10-04-2018, 01:09 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I think they should get a DNA test, they might be brothers, LOL.
