CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Welcome to OCC > Get To Know The Members
Old 06-30-2018, 08:22 AM
ynpmoose ynpmoose is offline
Default New HDS 2155 owner
Just picked up a used HDS 2155 that was a Cub dealer trade. 650 hours on the clock. It had a blown head gasket, which the dealer repaired. This tractor has very little rust on the deck, and almost no rust on the tractor itself. Hydro runs quiet. The only issues are on shutdown, it sometime bangs pretty good. I can see that the clutch pin and the part of the clutch housing that hit it are quite dented. Also, you have to press reverse down as far as possible to get it to move backwards, and it seems to be too slow in reverse. Hopefully this last one is just an adjustment.
HDS 2155 15HP 42” Hydro Shaft-drive
Old 06-30-2018, 08:44 AM
nophun nophun is offline
Reverse problem is common on this series, some have an adjustable link under the footrest that will help some.
There are plastic bushings that the direction control rides in, 2 on each side, the right wear more because that's where all of the pressure is applied. If you look under the right footrest with the deck down, you'll be able to see where the slop in the linkage is; in the mean time, just hook your foot under the forward pedal and pull back to get a little more reverse.
Old 06-30-2018, 10:18 AM
Inspector Gadget Inspector Gadget is offline
Since you just picked it up from a dealer, perhaps these issues would be covered under warranty. You might want to look into that before digging into it yourself.
Old 06-30-2018, 02:00 PM
It was as-is, no warranty. Thanks for the tips on the pedal.
Old 07-01-2018, 02:14 AM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
Shut the motor down at half throttle , that is what the book recommends
Oz
Thread Tools
Display Modes
